ecco le specifiche stanno a pagina 4 di questa discussione
Trance X e+1 PRO 29"
Trance X E+2 Pro 29"
Trance X E+ 3 PRO 29"
[/QUOTE]
| Frame | ALUXX SL-grade aluminum, Advanced forged composite upper rocker, 140mm Maestro suspension system |
| Fork | Fox 36 Float Performance, 150mm travel, 44mm offset, Grip 3-position, Micro Adjust damper, Boost 110x15QR, e-optimized |
| Shock | Fox Float DPX2 Performance,EVOL Large Volume sleeve, 3-Pos Lever, 185x52.5mm Trunnion mount |
| Handlebar | Giant Contact 35 Trail, 35x780mm |
| Grip | Giant Tactal single lock-on |
| Stem | Giant Contact SL 35 |
| Seatpost | Giant Contact Switch, dropper, 30,9mm (S:125, M: 150, L/XL:170) |
| Saddle | Giant Contact Trail, Neutral |
| Pedal | Flatpedal |
| Shifters | Shimano Deore XT, 12-speed i-spec EV |
| Front Derailleur | MRP 1X custom "V3" co-moulded TR chain guide |
| Rear Derailleur | Shimano Deore XTR, 12-Speed, Shadow+ |
| Brakes | Shimano Deore XT, BR-M8120, 4-piston, hydraulic disc, 203mm |
| Brake Levers | Shimano Deore XT, BL-M8120 i-spec EV |
| Cassette | Shimano CS-M7100-12, 10-51T, 12-Speed |
| Chain | KMC e.12 Turbo, EcoProteq, e-bike optimized |
| Crankset | Praxis Wavetm 36T Cold Forged 4130 premium steel Praxis e-Cadet+ custom forged crankarm set (Q-factor=168, XS/S:160, M/L:165, XL:170) |
| Bottom Bracket | N/A |
| Rims | Giant e-TR1 29, Tubeless ready, 30mm inner width |
| Hubs | Giant e-TR1 [F] 110x15 [R] 148x12mm Thru-axle |
| Spokes | Giant e-TR1 |
| Tires | Maxxis Assegai 29x2.6" foldable, Tubeless, EXO, 3c MaxxTerra[F] Maxxis Dissector 29x2.6" Foldable, Tubeless, EXO+, 120tpi 3C Compound [R] |
| Extras | Giant EnergyPak Smart 6A charger Tubeless kit (liquid, valves, levers, manual, tool) Inner tube supplied |
| Motor | Yamaha/Giant SyncDrive Pro |
| Controls | Giant RideControl One remote |
| Display | Giant RideCotrol Plus wireless (optional) |
| Battery | Giant EnergyPak Smart 625, 36V 17.3Ah integrated Lithium-Ion |
| Fork | Fox 36 Float Rhythm, 150mm travel, 44mm offset, EVOL, Grip Damper, Sweep adjust, Boost 110x15QR, e-optimized |
| Shock | Fox Float DPS Performance, EVOL Large Volume sleeve, 3-position Lever, 185x52.5mm Trunnion mount, custom tuned |
| Pedal | Flatpedal |
| Shifters | Shimano SLX 12-speed i-spec EV |
| Front Derailleur | MRP 1X CS custom |
| Rear Derailleur | Shimano Deore XT, 12-Speed, Shadow+ |
| Brakes | Shimano Deore BR-M6120, 4-piston, hydraulic disc, 203mm |
| Brake Levers | Shimano Deore BL-M6120 i-spec EV |
| Cassette | Shimano CS-M6100-12, 10-51T, 12-speed |
| Rims | Giant AM 29", Tubeless ready, 30mm inner width |
| Hubs | Shimano Boost, Center-Lock, [F] 110x15 [R] 148x12mm Micro-Spling Drive Body Thru-axle |
| Spokes | Sapim E-Lite [r] Race [f] |
| Tires | Maxxis Assegai 29x2.6" foldable, Tubeless, EXO [F] Maxxis Dissector 29x2.6" Foldable, Tubeless, EXO+ [R] |
| Fork | Rock Shox 35 Gold RL DebonAir, 150mm travel, 44mm offset, MotionControltm rebound and lockout control, 15x110 Boost, Maxle Stealth |
| Shock | Fox Float DPS Performance, EVOL Large Volume sleeve, 3-position lever, 185x52.5mm Trunnion mount, custom tuned |
| Pedal | Flatpedal |
| Shifters | Shimano Deore 12-speed i-spec EV |
| Rear Derailleur | Shimano Deore 12-speed |
| Brakes | Shimano BR-M420, 4-piston, hydraulic disc, 203mm |
| Brake Levers | Shimano Deore BL-M4100 i-spec EV |
| Crankset | Praxis Wavetm 36T Cold Forged 4130 premium steel Praxis e-Cadet+ custom forged crankarm set (S/M:160, L/XL:165) |
