Rumors modelli 2024
7.587
Freefra
2 Agosto 2021
1.287
1.285
Biella
Santa Cruz Heckler 9
Entambi retrocompatibili.
Fazua press release with the following just received
FAZUA RIDE 60 product news 2025: second battery and new MODE CONTROL planned
FAZUA is entering the race from 2025 with a new battery option: the permanently installed FAZUA Energy 480 delivers even more riding fun
The FAZUA MODE CONTROL is specially designed for use on E-MTBs and offers a new activation of the boost function for difficult passages
Ottobrunn, July 2, 2024. FAZUA is presenting two innovations for the FAZUA RIDE 60 at Eurobike in Frankfurt. From 2025, brand partners will have the choice of two battery options. The drive manufacturer from Ottobrunn near Munich is also presenting a new MODE CONTROL especially for sporty applications.
Unlimited riding fun with two different battery options
Developing a battery is Tetris for professionals. It's about combining the right number of lithium cells for a long range and the smart battery management system in the most compact housing possible. To give manufacturers more flexibility in the design of their e-bikes, FAZUA will offer them a choice of two battery options from 2025. The well-known FAZUA Energy 430 battery provides the rider with 430 watt hours of capacity and can either be charged on the chassis or removed.
The permanently installed FAZUA Energy 480 battery is new: thanks to innovative cell technology, it provides even more range. With an identical design and a weight of 2.2 kilograms, the new generation of battery cells provides 50 watt hours more capacity. This corresponds to an increase in range of up to ten percent. The battery is permanently installed in the down tube and is charged directly on the bike via the charging socket. Riders with existing bikes can have the battery retrofitted at the dealer as soon as it is available.
New FAZUA MODE CONTROL for full concentration on the trail
In addition to the tried-and-tested FAZUA RING CONTROL, FAZUA now also offers an alternative control element: the FAZUA MODE CONTROL. It also bundles a variety of functions in a user-friendly remote that is easy to operate and can be optimally integrated alongside other components on the handlebars. Riders can easily switch between different riding modes with their thumb over the rocker lever. Clever additional feature: the boost function can be activated simply by pressing a button. This means that the rider immediately has more power available on demanding passages. This keeps the focus exactly where it belongs - on the trail.
The design and robustness of the FAZUA MODE CONTROL are specially designed for sporty mountain biking and reliably protect the inner workings from water, mud and dust. As part of the FAZUA RIDE 60 product family, the MODE CONTROL is compatible with the FAZUA LED HUB. The innovative control unit takes the riding experience to a new level and can also be retrofitted to bikes with the FAZUA RIDE 60 system.
skaas
6 Settembre 2022
3.529
3.515
Brianzawood
LP
Quindi… se ho ben capito…
-Batteria portata da 430 a 480 con celle nuove mantenendo stesso ingombro fisico e peso (sostituibile all’attuale)
- “nuovo” control, anche se mi sembra che il ring rimanga, hanno solo messo un tasto per l’extraboost - 10’sec di gloria - al posto che tenere premuto il ring per 2sec per attivarlo… forse era meglio eliminare proprio il sistema ring a favore di tasti piu’ comodi…
Alone
17 Maggio 2019
1.751
798
Chiantishire
Scor 4060Z LT
Questo nuovo step di batteria, secondo me, allontana ancora di più l’eventuale arrivo di un range extender. Devono avere davvero tante difficoltà a farlo funzionare.. dopo due anni di promesse.
Reactions: Northman57
skaas
6 Settembre 2022
3.529
3.515
Brianzawood
LP
Mah ti diro’ … 430 a 480 non sopperisce certo ad un mancato extender… hanno aggiornato solo la batteria con celle migliori per me e tenendo lo stesso ingombro, hanno sfruttato quei 50wh in piu’ …
Alone
17 Maggio 2019
1.751
798
Chiantishire
Scor 4060Z LT
certo...ma il fatto che si siano dedicati a questo sviluppo, mi fa' pensare che sull'extender abbiano ancora tanti problemi.
giamma84
4 Febbraio 2021
163
226
PR
S.C.H.mx
Si ma da qui ad eliminare un extender… la vedo una mossa non favorevole a fazua in questo caso … sono in ritardo, e’ palese la cosa… spero solo …che sia studiato in maniera diversa rispetto al bosch
bah..che sia studiato in maniera diversa sicuro..migliore dagli indizi ne dubito..la mia (Fazua Ride60) ha un foro sull'obliquo con un tappo in gomma per un futuro "extender cable", inoltre è prevista una piastrina con 4 viti per chiudere la porta di alimentazione (che tra l'altro è in una zona spazzata dalla rotazione della pedivella quindi dubito effettivamente che un futuro extender si attacchi dalla porta di ricarica..).
Schermata 2024-07-02 alle 10.18.23.png Schermata 2024-07-02 alle 10.21.18.png
Mi vien da dire che o è qualcosa di mai visto rispetto agli altri extender, o sono ancora in alto mare...
Per fortuna o purtroppo al momento non ne ho la necessità...
marco
Pachidermica©
Diretur
13 Settembre 2016
3.100
3.999
Monte Bar
www.mtb-mag.com
Diverse
TC
KM Percorsi
Northman57
29 Novembre 2019
1.157
722
Friuli
Orbea Wild FS M10 2020
Raymon sta per lanciare la light Kyrok, 150mm e Bosch SX. Molto interessante. Poche informazioni per ora, solo su FB/Instagram.
In pratica pare si stiano "ribrandizzando". Lasceranno totalmente Yamaha?
marco
Pachidermica©
Diretur
13 Settembre 2016
3.100
3.999
Monte Bar
www.mtb-mag.com
Diverse
TC
KM Percorsi
