E bike light
Mttgrg
30 Luglio 2019
836
718
Napoli
Io ho provato il Brose I generazione con una kenevo, poi l’Ep8 con una Heckler Mx ed ora sono tornato a Brose con una Levo 22. Al netto delle differenze telaiistiche trovo il Brose nettamente più raffinato ed evoluto rispetto allo Shimano; con questo avevo perso il gusto di “power stage” in salita dove murava proprio nei momenti in cui avevi bisogno di maggior spinta; con il Brose ho riscoperto il gusto della salita “impestata”. Inoltre a livello software Shimano mi sembra molto più acerba rispetto a Mission Control. Trovo, poi, geniale e divertentissimo il microtune di specialized.
7.571
Anche in questo confronto aenvedi cosa dicono: ;) :cool:
Power:
This is an easy win for the Brose Drive S-Mag. On paper it produces up to 90Nm of torque and supports your effort by up to 410 per cent. In the saddle that power is equally impressive, even when you’re revving the cranks, and the torque really packs a punch when accelerating and tackling steep technical climbs.
Next, and not far behind, is the new Bosch Performance Line CX. It can’t quite match the Brose for either power or support (340 per cent and 85Nm) but in most situations it feels strong as an ox with stacks of power to lean on.
Lagging a little behind is the Shimano STEPS E8000. It lacks a bit of torque compared to the competition (70Nm) and you’ll notice that if you’re riding with people equipped with Bosch or Brose. In isolation, it’s not normally an issue, unless you weigh a lot or like drag races and seeking out the gnarliest climbing challenges around.
However the Shimano EP8 motor, on paper at least, brings the torque figure up to 85Nm and makes that power a lot more accessible to the rider through brand new software. The new Trail mode lets you tap into all that power and tune the characteristics to your heart’s content with the new e-Tube app. So far we’ve been impressed with the new motor’s light weight, low noise, compact size and improved engagement, but it doesn’t quite feel as powerful as its two main rivals.
È ciò che dicono molti che lo hanno provato. E una fonte autorevole come quella che hai citato, conferma. "However the Shimano EP8 motor, on paper at least, brings the torque figure up to 85Nm..." e "but it doesn’t quite feel as powerful as its two main rivals.".
Dunque par di capire che se Brose ha 90 nm reali e Bosch 85 reali (o comunque in proporzione) Shimano ne avrà 75...
(ooops ma dovevo chiedere il permesso a @velocipede per dirlo? Epperò stavolta lo dice mbr :D)
Reactions: MARCO GRANO
7.571
Per chi pensa che le ebike light siano vendutissime contando i post sui social, ecco una parere autorevole. Giusto per corretta informazione visto che le ebike costano migliaia di euro
yura
3 Febbraio 2022
2.006
3.965
Varesott
Orbea Rallon & Orbea Rise
....averlo letto prima 'sto commento sarei andato sicuro su una mega-batteria in modo tale da uniformarmi al mercato e non sentirmi un povero pirla.
Pisz&Lovv
;) :blush:
Motor Center
22 Ottobre 2022
365
207
Villa Cortese
io i giri alpini li riesco a fare tutti anche con questa elettr.chiaro che se devi spallare 30 min piu é leggera .meglio è,io nn trovo nessun giro fin ora precluso se nn lo vai a cercare apposta...guarda,io mi sento molto wild,ma mi stà sul cazzo sta moda ultima di cercare l estremo a tutti i costi x appagare l ego,io cerco divertimento e normalitá
se mi devo spallare la bici per 30 minuti... vuol dire che ho sbagliato percorso e mezzo, prendo la bici e la butto nel dirupo e proseguo a piedi, che tanto alla fine della salita il selfie con le montagne me lo faccio lo stesso :laughing:
yura
3 Febbraio 2022
2.006
3.965
Varesott
Te io mi sono uniformato con 700 w....ma lé stèss,sempre povero e pirla :cool: :cool: :cool: o_O o_O o_O .Brakky:kissing_heart:
Quello che volevo dire Brack è che ciascuno prende ciò che fa al caso suo: light (o presunte tali), semi light, semi full, full mega full e motorette.
Penso che possiamo dire che il mercato ci offre un sacco di alternative (per fortuna) tra le quali scegliere. Ciascuno, a seconda delle proprie necessità e del tipo di attività che predilige, può scegliere tra le diverse tipologie di mezzi.
Quel che mi da un pò noia sono le sentenze, il sentirmi dire come devo usare la mia bici e il pontificare il proprio credo come un dogma, da una parte e dall' altra eh.
Che poi mi va anche bene, si fanno quattro risate sul forum che se dovessimo pensare solo al lavoro a ghèe de sparass in di bàal !
:p ;) :blush:
yura
3 Febbraio 2022
2.006
3.965
Varesott
Ecco vedi, questa è un' altra opinione, la rispetto e la capisco anche.
L' ho sentita un sacco di volte anche sul forum marrone dal quale "provengo".
Spesso quando ho pubblicato degli itinerari alpini un pò particolari mi son sentito dire che era meglio andarci senza bici, o peggio ancora che era solo esibizionismo (de che poi). Però se quei 30 minuti di fatica mi consentono poi di poter fare una discesa della madonna di 2000 d+ (e oltre ma anche meno...dipende) IO me li faccio più che volentieri. Però capisco che per altri è inconcepibile.
Ovviamente certi percorsi non diventeranno mai delle classiche iper-frequentate...per fortuna dico io !!!
emtb-light
7 Settembre 2022
972
1.267
trento
orbea rise
Possibile che sia così difficile rispettare anche chi la pensa diversamente? Se uno vuole spallare una bici per mezz'ora, che problema c'è? Mica l'ha messa in spalla a te! la porta lui...
Ci possono essere mille motivi per fare 30 minuti di portage, anche solo sfidare se stessi in una discesa impossibile. Mettere alla prova le proprie abilità tecniche, migliorarsi..
E' proprio vero che l'aumento del numero di persone che praticano mtb/emtb ha portato ad un abbassamento del livello medio.. in paganella venerdì ci sono stati 5 interventi per soccorrere biker, in un giorno.. si buttano giù per un bike park e non sanno stare in equilibrio nemmeno da fermi.. motori da millemila watt e batterie da 1kWh, perché l'importante è non restare a secco, non divertirsi e faticare.. peccato, anche solo 10 anni fa il mondo bike aveva un livello più alto e soprattutto una apertura mentale mooolto più ampia. Adesso se hai una light ti dicono che sei pirla, se hai una batteria da 500Wh non capisci niente e se spalli una bici per mezz'ora sei da crocifiggere..
3.203
... anche solo 10 anni fa il mondo bike aveva un livello più alto e soprattutto una apertura mentale mooolto più ampia. ..
Infatti, basta andare sul marrone, ma anche su qualsiasi forum/chat di "ciclisti dentro" anche 10 anni fa. Una apertura mentale che levati! :joy:
Paolo25
23 Marzo 2017
2.162
1.182
Kenevo sl expert
A mio avviso invece il livello si e' alzato e anche di molto, pero' esponenzialmente e' anche aumentato il numero di chi pratica mtb, grazie proprio alla diffusione delle elettriche, 15anni fa qui da me praticamente ci si conosceva tutti e quando si saliva faticando sulle montagne si incontrava sempre le stesse persone ora si trovano carbone di gente sui sentieri, pero' oltre a vedere il classico "signore" con qualche kg di troppo che lo vedi che non ha mai pedalato qualcosa in vita sua si vedono anche parecchie persone che salgono in posti che prima dovevi conquistarti con ore di portage.
Io mi sono spinto la bici per parecchi giri, a 50anni mi e' passata la voglia se esco in bici lo faccio per starci in sella se devo camminare ci vado senza bici, pero' capisco benissimo chi lo fa e perche lo fa, il mondo e' bello perche' e' vario, quindi pedalate cosa volete e non pensate a quello che pensano gli altri!!
P.s. sono passato a una light e non vedo l'ora di provarla per pura curiosità'!
12.806
Ma come ??? Vuoi dirmi che al raduno dei ciclopirloni non c'è da spallare ALMENO mezz'ora ?!?!?!?...mi cancello subito eh !!
:joy::joy::joy:
Ti porto al tagliaferri a te socio...dato che sei buono con que casso di google metti..schilpario start..passo del vivione..passo del gatto..passo del venerocolo..laghetti omonimi..passo del vô..passo del deminione e rifugio...sono un cazzo di dislivello 1700 d+ scarsi..valgono x 2500 giro piu bello delle orobie x mè..imparato dai jagboys.fatto 4/5 volte muscolare e 4/5 con elettrica...paradisoBrakky
  • Love
Reactions: yura
3.203
Mettili nell'ordine giusto però Brakky, sulla mia mappa il passo del Demignone sta tra il passo del Venerocolo e il passo del Vo ... o forse è la sequenza come te la ricordi dopo il barile di grappa del rifugio? :joy: Rifugio, è il Tagliaferri? Comunque provo a cavarci una traccia gpx , prima o poi un giro in zona lo faccio.
Reactions: bracchetto scout
12.806
Si sono andato a memoria e sono anziano oramai :D dopo cerco due foto..figa son 18 passi ne ho invertiti dueo_Oo_Oo_O.l anno scorso é crollata una passerella..no 2 anni fà..variante alpina ziocannone 45 min con catene a spingere in 2 una bici alla volta x 50 cm ogni spinta....son stato buono di inventare nuove parolacceBrakky
Reactions: orli68 and yura
MAX80BO
7 Maggio 2019
298
484
STPJ 2017
Secondo il mio modesto parere è semplicemente il modo di vivere la mtb/emtb che è diverso.
Io ho una Levo, ma sono abituato a salire a velocità muscolare e godermi il paesaggio (la salita fa parte integrante del giro). Non ho la smania di fare 4o5 discese, ma questo è come sono abituato io e se mi supera uno che sale al triplo lo saluto senza giudicare il suo utilizzo.
Ad esempio la settimana scorsa siamo andati io e 2 miei amici a fare il giro sulla diga pubblicato dal direttore. Loro avevano la mtb classica e io la Levo. Son salito con loro dove sono riusciti (ripeto per me salire ai 4o5 km non è un problema) e dove han spinto li ho aspettati. Quando abbiamo incontrato una frana mi hanno aiutato a portare di la la Levo e i suoi 24/25 kili tutto in tranquillità e serenità. Alla luce di questo utilizzo una emtb "light" potrebbe essere la scelta migliore.
Questo è solo uno dei mille modi di vivere questo sport, ma forse è il caso di smetterla di pensare di essere portatori dell'utilizzo perfetto e baciarci i gomiti per le possibilità che danno questi mezzi.
Motor Center
22 Ottobre 2022
365
207
Villa Cortese
Spallare la mtb per 30 minuti l' ho fatto anche io una sola volta... su una mulattiera tutta sassosa, ci andavano su con il trial, ma la moto....so cosa vuol dire e la mia opinione è quella.. ma poi dico ho sputato l' anima per salire con una bici da 13kg... chissà con una da 20 o 25kg, per mè è masochismo, e sono anche volato in quella discesa di merda (che è durata 5 minuti...) perchè ero già stanco dalla salita...divertimento zero e ho rischiato anche di farmi male, perchè la tecnica si acquista prima con un corso e poi provando e riprovando, non facendo i kamikaze.
Per poi scoprire che dietro c' era la strada su asfalto:joy:, ci si infilava nel sentiero e si usciva li... e il 90% delle volte è così, ma bisogna fare fatica... bho mai capito e mai capirò... preferisco i sentieri e i trail ma arrivando e facendoli in bici, se devo andare a piedi vado a piedi, questo è il mio pensiero, gli altri facciano come vogliono.
Paradossalmente il problema delle elettriche è gente che non è mai andata in bici, sale ma poi non riesce a scendere
