Giant Trance SX E+ Pro 2019 - parte 3
mioro87
6 Settembre 2018
1.169
177
Macerata
Scapin
Novità 2021, cercando in rete sul sito dove vidi per la prima volta le trance con batterie da 625 ho trovato che hanno già a listino i modelli 2021, non ci sono ancora foto per quanto riguarda le colorazioni, vi metto l'allestimento :
Trance X e+1 PRO 29"
FrameALUXX SL-grade aluminum, Advanced forged composite upper rocker, 140mm Maestro suspension system
ForkFox 36 Float Performance, 150mm travel, 44mm offset, Grip 3-position, Micro Adjust damper, Boost 110x15QR, e-optimized
ShockFox Float DPX2 Performance,EVOL Large Volume sleeve, 3-Pos Lever, 185x52.5mm Trunnion mount
HandlebarGiant Contact 35 Trail, 35x780mm
GripGiant Tactal single lock-on
StemGiant Contact SL 35
SeatpostGiant Contact Switch, dropper, 30,9mm (S:125, M: 150, L/XL:170)
SaddleGiant Contact Trail, Neutral
PedalFlatpedal
ShiftersShimano Deore XT, 12-speed i-spec EV
Front DerailleurMRP 1X custom "V3" co-moulded TR chain guide
Rear DerailleurShimano Deore XTR, 12-Speed, Shadow+
BrakesShimano Deore XT, BR-M8120, 4-piston, hydraulic disc, 203mm
Brake LeversShimano Deore XT, BL-M8120 i-spec EV
CassetteShimano CS-M7100-12, 10-51T, 12-Speed
ChainKMC e.12 Turbo, EcoProteq, e-bike optimized
CranksetPraxis Wavetm 36T Cold Forged 4130 premium steel
Praxis e-Cadet+ custom forged crankarm set (Q-factor=168, XS/S:160, M/L:165, XL:170)
Bottom BracketN/A
RimsGiant e-TR1 29, Tubeless ready, 30mm inner width
HubsGiant e-TR1 [F] 110x15 [R] 148x12mm Thru-axle
SpokesGiant e-TR1
TiresMaxxis Assegai 29x2.6" foldable, Tubeless, EXO, 3c MaxxTerra[F]
Maxxis Dissector 29x2.6" Foldable, Tubeless, EXO+, 120tpi 3C Compound [R]
ExtrasGiant EnergyPak Smart 6A charger
Tubeless kit (liquid, valves, levers, manual, tool)
Inner tube supplied
MotorYamaha/Giant SyncDrive Pro
ControlsGiant RideControl One remote
DisplayGiant RideCotrol Plus wireless (optional)
BatteryGiant EnergyPak Smart 625, 36V 17.3Ah integrated Lithium-Ion
Trance X E+2 Pro 29"
ForkFox 36 Float Rhythm, 150mm travel, 44mm offset, EVOL, Grip Damper, Sweep adjust, Boost 110x15QR, e-optimized
ShockFox Float DPS Performance, EVOL Large Volume sleeve, 3-position Lever, 185x52.5mm Trunnion mount, custom tuned
PedalFlatpedal
ShiftersShimano SLX 12-speed i-spec EV
Front DerailleurMRP 1X CS custom
Rear DerailleurShimano Deore XT, 12-Speed, Shadow+
BrakesShimano Deore BR-M6120, 4-piston, hydraulic disc, 203mm
Brake LeversShimano Deore BL-M6120 i-spec EV
CassetteShimano CS-M6100-12, 10-51T, 12-speed
Bottom BracketN/A
RimsGiant AM 29", Tubeless ready, 30mm inner width
HubsShimano Boost, Center-Lock, [F] 110x15 [R] 148x12mm Micro-Spling Drive Body Thru-axle
SpokesSapim E-Lite [r] Race [f]
TiresMaxxis Assegai 29x2.6" foldable, Tubeless, EXO [F]
Maxxis Dissector 29x2.6" Foldable, Tubeless, EXO+ [R]
Inner tube supplied
Trance X E+ 3 PRO 29"
ForkRock Shox 35 Gold RL DebonAir, 150mm travel, 44mm offset, MotionControltm rebound and lockout control, 15x110 Boost, Maxle Stealth
ShockFox Float DPS Performance, EVOL Large Volume sleeve, 3-position lever, 185x52.5mm Trunnion mount, custom tuned
PedalFlatpedal
ShiftersShimano Deore 12-speed i-spec EV
Rear DerailleurShimano Deore 12-speed
BrakesShimano BR-M420, 4-piston, hydraulic disc, 203mm
Brake LeversShimano Deore BL-M4100 i-spec EV
Praxis e-Cadet+ custom forged crankarm set (S/M:160, L/XL:165)
Bottom BracketN/A
Inner tube supplied
i prezzi non si sanno ancora??
Andyz_it
4 Aprile 2018
1.581
606
Tortona
Giant Trance E+ SX 1 Pro
Non solo, può montare anche l'extender, da quale sito hai trovato le info? vedo iva al 16% per cui da noi i prezzi saranno di sicuro diversi
camero
26 Febbraio 2017
1.190
465
49
Italia
Buongiorno a tutti, il mozzo posteriore ha al suo interno degli anelli di spessore/scorrimento che quando l'ho smontato alcuni erano proprio messi male, sapete se si trovano in commercio? ho risolto il problema dell' end cap sfilettato e mi girano le scatole dover sostituire tutto il mozzo per così poco
camero
26 Febbraio 2017
1.190
465
49
Italia
gli hanno fatto la zona motore come la reign molto più importante dell’attuale 2020; non mi convince tantissimo; sarà più alta o più bassa dell‘attuale zona motore anche in via dell’adozione delle 29??
diciamo che l'integrazione motore non è mai stata un granché, tant'è vero che molti davano la colpa proprio alla forma del motore, poi raymon ha dimostrato che di meglio si poteva fare
Andyz_it
4 Aprile 2018
1.581
606
Tortona
in pratica hanno usato il telaio della reign con una forca da 150 con le 29"
ora il fatto che ci sia il flip chip se così si chiama non capisco a cosa possa servire, abbassare ulteriormente se poi hai il rischio di cozzare con il motore
Andyz_it
4 Aprile 2018
1.581
606
Tortona
prova ad andare in un negozio di cuscinetti con quello che ne rimane, fatti dare un rasamento
camero
26 Febbraio 2017
1.190
465
49
Italia
si grazie, infatti oggi sono risceso in garage e ho constatato che quegli "anelli" sono il rimanente di qualcosa più grande :D .
comunque il mozzo originale completo costa 75 euro e siccome dovevo farmi anche un po' di kilometri per andarlo a prendere, mentre spippolavo ho trovato un mozzo nukeproof horizon in sconto (ultimo pezzo) a 83 euro... quindi l'ho ordinato. o vediamo se ora funziona!!!!
si lo so mozzo sprecato per una ruota di merda però per 8 euro di differenza.....
Andyz_it
4 Aprile 2018
1.581
606
Tortona
io credo che il cerchio non sia male, sono i cuscinetti dei mozzi giant che fanno pietà ma.... non tutti
la liv di mia moglie per esempio, il suo mozzo post canta come il mio hope e gira che è una meraviglia, forse ho beccato un lotto migliore
camero
26 Febbraio 2017
1.190
465
49
Italia
più che i cuscinetti forse il corpetto, comunque anch'io in linea di massima non posso lamentarmi.... ma ora:
my next hub....
shrubber83
6 Luglio 2018
2.502
1.344
Sesto Fiorentino
Varie...
Sono delle boccole che si consumano
Io ne presi una decina e le limai alla giusta larghezza per usarle come ricambio.
Poi mi hanno cambiato il mozzo in garanzia e cmq ho cambiato le ruote...
codix
9 Ottobre 2018
634
311
Novi Ligure
Fulgur mula
Ciao a tutti,
ho cercato di leggere tutte le quasi 400 pagine dedicate a questo modello , cercando di capire il piu` possibile le caratteristiche di questa bike e dei suoi componenti, ma, al fine di comprendere meglio se sia la bici giusta per, me approfitto della vostra esperienza per porvi alcune domande.
Premetto che attualmente ho un Whistle B-rush SL del 2018 con bosch CX gen 2 e sospensioni FOX, di cui sono piuttosto soddisfatto ma che passerei a moglie e figlio i quali si sono da poco appassionati questo sport.
I nostri giri sono molto diversificati, passiamo dai boschi alle vigne e anche a qualche tratto di asfalto che ci permette di raggiungere i posti di nostro interesse. Non frequentiamo i bike park e non abbiamo la capacita` lanciarci in discese molto tecniche, per cui potrei definire il nostro, un utilizzo abbastanza tranquillo.
Volendo acquistare un altra bike, ho trovato una Giant trance e+ 0 usata ad un prezzo che rientra nel mio budget ma essendo il venditore lontano dalla mia zona, non ho modo di provarla per tempo, vi chiederei pertanto le seguenti vostre impressioni .
Motore: avete avuto modo di confrontarlo rispetto al bosch CX gen 2 ? se si quali sono le differenze in termini di erogazione alle basse cadenze? Io non frullo molto in alto, max 80 rpm e mi piacerebbe avere piu` coppia in questo range di giri.
Qualita` costruttiva della bici: io con Whistle non ho mai avuto alcun problema... come vi trovate con Giant?
Autonomia : so bene che e` un dato assolutamente variabile , ma per farvi un esempio io che peso 86kg , con la whistle ho fatto 1100 mt di dislivello e 60km tornando a casa con il 30% di batteria. Premetto che ho utilizzato solo Eco settato al 40% e tour che e` 120%. Con giant riusciro` a fare percorrenze simili?
Gestione del motore tramite app: io ho il nyon che permette di settare le assistenze e fornisce tutta una serie di info oltre che essere un navigatore;
ho letto che Giant usa una app che fa le stesse cose ma che sta dando diversi problemi agli utenti, voi come vi trovate?
Vi ringrazio per aver letto questa mia (lunga) richiesta di info e rimango in attesa di vostre impressioni ed indicazioni!
