Novità 2021, cercando in rete sul sito dove vidi per la prima volta le trance con batterie da 625 ho trovato che hanno già a listino i modelli 2021, non ci sono ancora foto per quanto riguarda le colorazioni, vi metto l'allestimento :
Trance X e+1 PRO 29"
Frame ALUXX SL-grade aluminum, Advanced forged composite upper rocker, 140mm Maestro suspension system Fork Fox 36 Float Performance, 150mm travel, 44mm offset, Grip 3-position, Micro Adjust damper, Boost 110x15QR, e-optimized Shock Fox Float DPX2 Performance,EVOL Large Volume sleeve, 3-Pos Lever, 185x52.5mm Trunnion mount Handlebar Giant Contact 35 Trail, 35x780mm Grip Giant Tactal single lock-on Stem Giant Contact SL 35 Seatpost Giant Contact Switch, dropper, 30,9mm (S:125, M: 150, L/XL:170) Saddle Giant Contact Trail, Neutral Pedal Flatpedal Shifters Shimano Deore XT, 12-speed i-spec EV Front Derailleur MRP 1X custom "V3" co-moulded TR chain guide Rear Derailleur Shimano Deore XTR, 12-Speed, Shadow+ Brakes Shimano Deore XT, BR-M8120, 4-piston, hydraulic disc, 203mm Brake Levers Shimano Deore XT, BL-M8120 i-spec EV Cassette Shimano CS-M7100-12, 10-51T, 12-Speed Chain KMC e.12 Turbo, EcoProteq, e-bike optimized Crankset Praxis Wavetm 36T Cold Forged 4130 premium steel
Praxis e-Cadet+ custom forged crankarm set (Q-factor=168, XS/S:160, M/L:165, XL:170)Bottom Bracket N/A Rims Giant e-TR1 29, Tubeless ready, 30mm inner width Hubs Giant e-TR1 [F] 110x15 [R] 148x12mm Thru-axle Spokes Giant e-TR1 Tires Maxxis Assegai 29x2.6" foldable, Tubeless, EXO, 3c MaxxTerra[F]
Maxxis Dissector 29x2.6" Foldable, Tubeless, EXO+, 120tpi 3C Compound [R]Extras Giant EnergyPak Smart 6A charger
Tubeless kit (liquid, valves, levers, manual, tool)
Inner tube suppliedMotor Yamaha/Giant SyncDrive Pro Controls Giant RideControl One remote Display Giant RideCotrol Plus wireless (optional) Battery Giant EnergyPak Smart 625, 36V 17.3Ah integrated Lithium-Ion
Trance X E+2 Pro 29"
Frame ALUXX SL-grade aluminum, Advanced forged composite upper rocker, 140mm Maestro suspension system Fork Fox 36 Float Rhythm, 150mm travel, 44mm offset, EVOL, Grip Damper, Sweep adjust, Boost 110x15QR, e-optimized Shock Fox Float DPS Performance, EVOL Large Volume sleeve, 3-position Lever, 185x52.5mm Trunnion mount, custom tuned Handlebar Giant Contact 35 Trail, 35x780mm Grip Giant Tactal single lock-on Stem Giant Contact SL 35 Seatpost Giant Contact Switch, dropper, 30,9mm (S:125, M: 150, L/XL:170) Saddle Giant Contact Trail, Neutral Pedal Flatpedal Shifters Shimano SLX 12-speed i-spec EV Front Derailleur MRP 1X CS custom Rear Derailleur Shimano Deore XT, 12-Speed, Shadow+ Brakes Shimano Deore BR-M6120, 4-piston, hydraulic disc, 203mm Brake Levers Shimano Deore BL-M6120 i-spec EV Cassette Shimano CS-M6100-12, 10-51T, 12-speed Chain KMC e.12 Turbo, EcoProteq, e-bike optimized Crankset Praxis Wavetm 36T Cold Forged 4130 premium steel
Praxis e-Cadet+ custom forged crankarm set (Q-factor=168, XS/S:160, M/L:165, XL:170)Bottom Bracket N/A Rims Giant AM 29", Tubeless ready, 30mm inner width Hubs Shimano Boost, Center-Lock, [F] 110x15 [R] 148x12mm Micro-Spling Drive Body Thru-axle Spokes Sapim E-Lite [r] Race [f] Tires Maxxis Assegai 29x2.6" foldable, Tubeless, EXO [F]
Maxxis Dissector 29x2.6" Foldable, Tubeless, EXO+ [R]Extras Giant EnergyPak Smart 6A charger
Trance X E+ 3 PRO 29"
Frame ALUXX SL-grade aluminum, Advanced forged composite upper rocker, 140mm Maestro suspension system Fork Rock Shox 35 Gold RL DebonAir, 150mm travel, 44mm offset, MotionControltm rebound and lockout control, 15x110 Boost, Maxle Stealth Shock Fox Float DPS Performance, EVOL Large Volume sleeve, 3-position lever, 185x52.5mm Trunnion mount, custom tuned Handlebar Giant Contact 35 Trail, 35x780mm Grip Giant Tactal single lock-on Stem Giant Contact SL 35 Seatpost Giant Contact Switch, dropper, 30,9mm (S:125, M: 150, L/XL:170) Saddle Giant Contact Trail, Neutral Pedal Flatpedal Shifters Shimano Deore 12-speed i-spec EV Front Derailleur MRP 1X CS custom Rear Derailleur Shimano Deore 12-speed Brakes Shimano BR-M420, 4-piston, hydraulic disc, 203mm Brake Levers Shimano Deore BL-M4100 i-spec EV Cassette Shimano CS-M6100-12, 10-51T, 12-speed Chain KMC e.12 Turbo, EcoProteq, e-bike optimized Crankset Praxis Wavetm 36T Cold Forged 4130 premium steel
Praxis e-Cadet+ custom forged crankarm set (S/M:160, L/XL:165)Bottom Bracket N/A Rims Giant AM 29", Tubeless ready, 30mm inner width Hubs Shimano Boost, Center-Lock, [F] 110x15 [R] 148x12mm Micro-Spling Drive Body Thru-axle Spokes Sapim E-Lite [r] Race [f] Tires Maxxis Assegai 29x2.6" foldable, Tubeless, EXO [F]
i prezzi non si sanno ancora??
