mi sa che ho pubblicato 1 ora troppo presto.
In ogni caso, i montaggi:
MITH PRO
MOTOR: DJI AVINOX
BATTERY: DJI 800Wh
DISPLAY: 2-inch OLED full-color touchscreen, 800 nits, 326 ppi
FORK: FOX 38 Factory, 170mm, 29”, GRIP X2, 44mm offset
SHOCK: FOX Float X2 Factory, 230x65mm
DROPPER: ONEUP V3 180mm, 31.6mm - 22.2mm
HEADSET: CANE CREEK 40, No cover, TPR-IS41/28.6/H9 | IS52/40
HANDLEBAR: ONEUP V2 Carbon, 35mm diameter, 800mm length, 35mm rise
STEM: ONEUP 42mm
GRIPS: ODI Elite Pro Lock-on (130mm)
FRONT WHEEL: NEWMEN Phase 30 Carbon, Base, 29”, 28h, FADE SP 6B, 15x110
REAR WHEEL: NEWMEN Phase 30 Carbon, Strong, 27.5”, 28h, FADE SP 6B, 12x148 XD
FRONT TIRE:
SCHWALBE Magic Mary, Ultra Soft, Gravity Pro, TLR, 29” x 2.5”
REAR TIRE: SCHWALBE Magic Mary, Soft Evo, Gravity Pro, TLR, 27.5” x 2.5”
BRAKES:
FORMULA Cura 4
ROTORS: FORMULA - 203mm (front), 200mm (back)
CHAIN:
SRAM X0 T-Type, 120 links
DERAILLEUR: SRAM X0 Eagle AXS T-Type
CONTROLLER: SRAM AXS Pod Rocker
CASSETTE: SRAM X0, XS 1295 T-Type, 10-52t
CRANKS: E13 Helix Core e*spec, 155mm
CHAINRING: UNNO 36t
SEAT: FIZIK Terra Aidon X5, 145mm
CHARGER: DJI 508 W Fast-charging
SIZES: S1, S2, S3
MSRP: 11.995€ (EU) - £9,995 (UK) - 10,295 CHF (SWISS)
MITH RACE
MOTOR: DJI AVINOX
BATTERY: DJI 800Wh
SHOCK: FOX Float X Factory, 230x65mm
HANDLEBAR: ONEUP V2 Alloy, 35mm diameter, 800mm length, 35mm rise
STEM: ONEUP 42mm
FRONT WHEEL: NEWMEN Performance 30 Alloy, Base, 29”, 28h, FADE SP 6B, 15x110
REAR WHEEL: NEWMEN Performance 30 Alloy, Strong, 27.5”, 28h, FADE SP 6B, 12x148 XD
FRONT TIRE: SCHWALBE Magic Mary, Ultra Soft, Gravity Pro, TLR, 29” x 2.5”
BRAKES: FORMULA Cura 4
CHAIN: SRAM 70 T-Type, 120 links
DERAILLEUR: SRAM S1000 Eagle AXS T-Type
CASSETTE: SRAM 70, XS 1270 T-Type, 10-52t
CHAINRING: UNNO 36t
SIZES: S1, S2, S3
MSRP: 9.995€ (EU) - £8,095 (UK) - 8,295 CHF (SWISS)
