infatti forse ho sbagliato qualcosa
Vai sul sito Rhentala me da 20 € di spedizione. Premesso che vorrei rise da 30 mm qual'é il più robusto? vanno bene per DH?
Ritornando alle novità 2027, eccone una succulenta marchiata Trek Fuel+ con motore TQ-HPR120 e batteria modulabile (330wh + 650wh e le puoi lasciare a casa una delle due o metterle in serie)
Vedi l'allegato 88649
Frame
OCLV Mountain Carbon, herausnehmbarer Akku, verstellbarer Steuersatzwinkel, verstellbares Hebelverhältnis, geführte internal cable and wire routing, austauschbare Aluminiumumlenkhebel, austauschbare untere Dämpferaufnahme, Unterrohrschutz, Shuttle-Protektor, ABP, UDH, Boost148, anpassbarer
Fork
FOX Rhythm 36, Float EVOL air springung, GRIP-damping, tapered steerer, 44 mm Vorbiegung, Boost110, 15 mm Kabolt-X-Achse, 150 mm travel
Shock
FOX Performance Float X, 2-Positionen-damping, 230 x 60 mm
Hubs (f/r)
v/f: Shimano TC500, Aluminium, Center Lock-disc mount, 110 x 15 mm thru-axle | h/r: Shimano TC500 Aluminium, Centerlock, 148x12 mm thru-axle
Rims
Bontrager Line TLR 30, Tubeless Ready, 32-hole, Presta valve // Bontrager Line TLR 30, Tubeless Ready, 28-hole, Presta valve
Tires
Maxxis Minion DHF, Tubeless-Ready, 3C, EXO+ casing, MAXXGRIP, folding bead, 29 x 2.50 // Maxxis Minion DHR II, Tubeless Ready, MaxxTerra, Double Down casing, folding bead, 27.5 x 2.5
Battery
Trek 980 Modular Battery System, 330wh 1p battery + 650wh 2p battery
Display unit
TQ LED-Farbdisplay mit Touch-Funktion und Bluetooth- &
Motor
TQ-HPR X, 120 Nm, 750w, 700% support
Rear derailleur
SRAM S1000 Eagle AXS, T-Type
Crankset
FSA, Aluminium, 160 mm crank arm length
Cassette
SRAM Eagle PG-1240, T-Type, 11-52 Z., 12fach
Chain
SRAM Eagle 70, T-Type, 12fach
Brakes
Shimano MT620 hydraulic disc brake // Shimano BR-MT620 hydraulic disc
Brake rotors
Shimano RT64, Centerlock disc mount, 203 mm
Saddle
Bontrager Verse Short, Edelstahlstreben
Seatpost
Bontrager Line Dropper, 150 mm Hub, MaxFlow, internal cable routing, 34,9 mm, 410 mm length
Handlebar
Bontrager Comp, Aluminium, 31,8 mm, 40 mm Rise, 780 mm width
Grips
Trek Line Comp, Nylonschraubklemmung
Stem
Bontrager Comp, 31,8 mm, 7 Grad, 35 mm length
Headset
FSA Orbit, gedichtetes Kompaktlager, 1 1/8 oben, 1,5 unten, 1,5 Gabelkonus
Da notare che anche TQ ha scelto di non farsi problemi con la coppia copiosa ma di autolimitarsi a 750 watt per la potenza massima...
In ogni caso deve essere prossima al lancio come testimonia questo shop online
Grazie, ma volevo sapere in che sito si trova.....
Fatto stesso ragionamentoStavo rguardando il profilo della bici e mettendo insieme alcune informazioni, mi è venuto un dubbio sulla disposizione delle due batterie.
Ho letto che la configurazione Park Mode utilizzi la sola 330 Wh, anziché senza batterie, e che venga specificato che la 650 Wh si sfila dal basso, questo mi potrebbe far pensare che le due batterie non siano ugualmente facili da rimuovere.
La mia ipotesi è che la 650 Wh sia quella pensata per essere messa e tolta agevolmente, mentre la 330 Wh sia posizionata quasi “integrata” nel telaio, magari vicino al motore. Sarebbe comunque rimovibile, ma intervenendo magari con qualche attrezzo e non con un quick release.
In questo modo si spiegherebbe bene il Park Mode proposto con la 330: sfili rapidamente la 650 e rimani con 330 Wh. Perche altrimenti il park mode non è semplicemente: "sfili entrambe le batterie"?
Quindi sostanzialmente due tipo di utilizzatori:
- Se pensi di utilizzare "stabilmente" la bici con la sola 650, smonti la 330 e la configuri così. Hai leggerezza e autonomia.
- Se pensi invece di utilizzare la bici stile full power ma fai anche risalite meccanizzate, la usi stabile con la 330 integrata e con la 650 che poi toglierai agevolmente per furgonate o park.
Quindi da un lato è vero che è un sistema interamente modulabile, ma con qualche limitazione pratica... non è che apri lo sportello e infili al volo al bisogno soltanto una delle due batterie che pensi di usare, o entrambe.
Forse è più un concetto di una light, dove il range extender di notevole capienza è stato collocato nel telaio per mantenere usabile la borraccia.
È solo una mia teoria eh.
Però è la bici che attualmente mi incuriosisce di piu....
Sono idiscrezioni che circolano in rete. Nessuna immagine su un sito ufficiale. Questa era stata presa da una pagina di uno shop online che la aveva caricata per sbaglio.Grazie, ma volevo sapere in che sito si trova.....
Beh un prodotto nuovo ed interessante direi.![]()
▷ La tua e-bike leggera e innovativa in magnesio | Un’e-bike di classe superiore – MAG Bike
E-bike in magnesio dal peso ridotto. 100% innovativa e riciclabile. ✓ E-bike estremamente leggera grazie al telaio in magnesio ► Scopri di più!www.mag-bike.com
fatto ora, speso 80,98 totaliinfatti forse ho sbagliato qualcosa
www.instagram.com
monta un disco post esagerato o non ha casetta con 52...strano .Eccola:
Vedi l'allegato 89246
Battery Trek 980 Modular Battery System, 330 Wh 1p battery + 650 Wh 2p battery
Display unit TQ color LED display with touch functionality, Bluetooth, and...
Motor TQ-HPR X, 120 Nm, 750 W, 700% support
