Suggerimenti di Giant:
When you remove the battery to store it, make sure it is in a safe, climate-controlled space. You should not store the battery while it is empty or has a very low charge.
If the bike is not used for a longer period (one month or more) the EnergyPak is best stored:
- At 60% of its capacity (3 out of 5 charging LEDs).
- Separate from the bike.
- At temperatures between 0°C and 40°C.
Check every month to see if at least one LED is still blinking. Charge when needed, at least every 3 months. Failing to do so could void the warranty. When charging the battery, make sure it is in a dry location. Also be sure that the EnergyPak and charger are in a place where they won’t cause a fire.
Follow these steps, and you will get the most from your EnergyPak.
