Giant E-Reign 2020
13.901
Giant 20 Reign E+ 1 Pro
Vedi l'allegato 21175
FRAME ALUXX SL-grade aluminum, 160mm Maestro suspension system, 'Boost' 148x12QR, Giant EnergyPak Plus range extender compatible
FORK Fox 36 Float Performance 27.5+, 170mm, 3-position Micro Adjust Grip Damper, Boost 110x15QR, e-Bike optimized
SHOCK Fox Float X2 Performance, EVOL Large Volume sleeve, 2-position lever, 205x62.5mm Trunnion mount, custom tuned
HANDLEBAR Giant Contact Trail, 35x800mm
STEM Giant Contact SL 35
SEATPOST Giant Contact Switch, dropper, 30,9mm (S:100/M:125/L:150/XL:170)
SADDLE Giant Contact, Neutral
SHIFTERS Shimano Deore XT, 12-speed
FRONT DERAILLEUR MRP 1X custom "V3" co-moulded TR chain guide
REAR DERAILLEUR Shimano Deore XT, 12-Speed, Shadow+
BRAKES Shimano Deore XT, BR-M8120, 4-piston, hydraulic disc, 203mm
BRAKE LEVERS Shimano Deore XT, BL-M8120
CASSETTE Shimano HG-M7100, 11-51T, 12-Speed
CHAIN KMC e.12 Turbo, EcoProteq, e-bike optimized
CRANKSET Praxis Wavetm 36T Cold Forged 4130 premium steel Praxis e-Cadet+ custom forged crankarm set (Q-factor=168, S/M:160, L/XL:165)
RIMS Giant e-TR1 27.5, Tubeless ready, 30mm inner width
HUBS Giant e-TR1 [F] 110x15 [R] 148x12mm Thru-axle
SPOKES Giant e-TR1
TIRES Maxxis Minion DHF 27.5x2.6" foldable, Tubeless, EXO+, 3c MaxxTerra[F] Maxxis High Roller II 27.5x2.6" foldable, Tubeless, DoubleDown, 2x120tpi, 3C MaxxTerra Compound [R]
EXTRAS Giant EnergyPak Smart 6A charger Tubeless kit (liquid, valves, levers, manual, tool)
MOTOR Giant Yamaha SyncDrive Pro
SENSORS Giant PedalPlus 6-sensor technology
DISPLAY Giant RideControl One
BATTERY Giant EnergyPak Smart 500, 36V 13.8Ah integrated Lithium-Ion
Giant 20 Reign E+ 2 Pro
Vedi l'allegato 21176
FORK Fox 36 Float Rhythm 27.5+, 170mm, Grip Damper, Sweep adjust, Boost 110x15QR, e-Bike optimized
SHOCK Fox Float DPX2 Performance, EVOL Large Volume sleeve, 2-position lever, 205x62.5mm Trunnion mount, custom tuned
SHIFTERS SRAM GX Eagle 12-speed
REAR DERAILLEUR SRAM GX Eagle 12-speed
BRAKES SRAM Guide RE, 4-piston, hydraulic disc, 200mm
BRAKE LEVERS SRAM Guide RE
CASSETTE SRAM Eagle PG-1230, 11-50T, 12-Speed
CHAIN SRAM NX Eagle PowerLock, 12-speed
CRANKSET SRAM X-Sync Eagle 36T 104BCD chainring Praxis e-Cadet+ custom forged crankarm set (Q-factor=168, S/M:160, L/XL:165)
RIMS Giant AM 27.5+, Tubeless ready, 35mm inner width
HUBS Giant eTracker Boost, Sealed cartridge bearing, 6-bolt, [F] 110x15 [R] 148x12mm Thru-axle
SPOKES Sapim E-Lite [r] Race [f]
MOTOR Giant SyncDrive Pro
Potevano chiamarla Moby Dick, anziché Reign: hanno messo un bicilindrico ad L, sotto quei “cofani”??? :D
Andyz_it
4 Aprile 2018
1.582
610
Tortona
Giant Trance E+ SX 1 Pro
ma il fatto che il motore nella parte anteriore sia così basso potrebbe essere dovuto al fatto che lo hanno ruotato in giù? diverssamente che senso avrebbe metterlo in quella posizione, a parte il fattore estetico che rovina tutta la bici, si è più a rischio di collisione.
Mondraker molto bella
MaxSantucci
12 Ottobre 2017
505
240
Moterra/Overvolt GLP2
SPOKES Giant e-TR1
c'è qualcosa di diverso la E+ 1pro ha un ammo diverso nella foto del catalogo :confused:
    255,7 KB · Visite: 77
    252,9 KB · Visite: 73
guecio
13 Maggio 2019
370
227
Sesto Fiorentno (FI)
Scott Genius E-Ride 920
Si concordo che sotto sia parecchio grossa, forse è una scelta per tenere il peso il + basso possibile, con mondraker è proprio diversa la filosofia, ha anche un carro posteriore molto lungo, magari per tenere il motore così alto hanno dovuto cercare stabilità allungandolo molto...
Viste così sembra che la giant sia molto maneggevole a discapito della poca luce sotto...
cmq a me sembrava abbondante la pancia della Trance... questa Reign è veramente bassa come motore. Bosch ha fatto decisamente meglio. la resa su Mondraker è spettacolare. Monta pure una 34T che è un po' più piccola e sembra ci sia meno differenza di quella reale
Si
8.463
Si
Mondraker il carro ERA lungo per via del vecchio bosch Cx , adesso ha un normalissimo 455 mm che per un ruota da 29 è abbastanza corto...il motore non è alto è semplicemente piccolo... ;)
buddys
27 Novembre 2016
74
15
Scandicci
Ciao a tutti, sono in attesa della E-Reign 0, mi fa specie che non abbiano messo la batteria da 600w, e una cosa che mi preoccupa e' il cambio axs: se con una botta si rompe ci vuole un mutuo per cambiarlo!
buddys
27 Novembre 2016
74
15
Scandicci
ma qualcuno ha già visto questo extender? sarà bello piccino perchè lo spazio non è molto, io che ho un XL come taglia volevo mettere il porta camera d'aria della topeak (il ninja mtb) che si fissa sotto al portaborraccia ed in pratica si ha un borsino che stà sotto al sedere della borraccia ma questo tocca contro l'ammo quando và in compressione, sarà mica un powerbank cinese?!?:joy:
Lo ho visto, e' molto piccolo e anche carino a vedersi: l' unico male e' che costera' un botto!
Andyz_it
4 Aprile 2018
1.582
610
Tortona
E+0 = 7599€
TaglieS, M, L, XL
ColorazioniChameleon Green / Gold
TelaioALUXX SL-grade aluminum, 160mm Maestro suspension system, 'Boost' 148x12QR, Giant EnergyPak Plus range extender compatible
ForcellaFox 36 Float Factory 27.5+, 170mm, Grip2 Damper, Boost 110x15QR, e-Bike optimized
AmmortizzatoreFox Float X2 Factory, EVOL Large Volume sleeve, 2-position lever, 205x62.5mm Trunnion mount, custom tuned
ManubrioGiant Contact SL 35 Trail, 35x800mm
Attacco manubrioGiant Contact SL 35
TubosellaSRAM Reverb AXS, Wireless Remote, dropper, 30.9mm (Travel: 100mm-S / 125mm-M / 150mm-L / 170mm- XL)
SellaGiant Contact SL, Neutral
Pedali-
Leve del cambioSRAM XO1 Eagle eTap AXS, e-bike synchronized
DeragliatoreMRP 1X custom "V3" co-moulded TR chain guide
CambioSRAM XO1 Eagle AXS
FreniSRAM Code R, hydraulic disc, 220mm [F] 200mm [R]
Comandi frenoSRAM Code R
Pacco pignoniSRAM PG-1230, 11-50T, 12-Speed
CatenaSRAM XO1 Eagle PowerLock, 12-Speed
GuarnituraSRAM X-Sync Eagle 36T 104BCD chainringPraxis e-Carbon custom carbon crankarm set (Q-factor=168, S/M:160, L/XL::165)
Drop movimento centraleN/A
CerchiGiant e-TRX 27.5, Tubeless ready, 30mm inner width
MozziGiant e-TRX [F] 110x15 [R] 148x12mm Thru-axle
RaggiGiant e-TRX
CopertureMaxxis Minion DHF 27.5x2.6" foldable, Tubeless, EXO+, 3c MaxxTerra[F]Maxxis High Roller II 27.5x2.6" foldable, Tubeless, DoubleDown, 2x120tpi, 3C MaxxTerra Compound [R]
ExtrasGiant EnergyPak Smart 6A charger Tubeless kit (liquid, valves, levers, manual, tool)
MotoreGiant SyncDrive Pro
SensorsGiant PedalPlus 6-sensor technology
DisplayGiant RideControl One
BatteriaGiant EnergyPak Smart 500, 36V 13.8Ah integrated Lithium-Ion
PesoQuanto pesa una bicicletta? E' una domanda che ci viene posta sovente. Non ci sono standard produttivi capaci di rispondere con esattezza dando indicazione sul peso delle biciclette. Esistono variazioni di peso in base alla taglia, alla composizione del telaio, alle finiture e alla componentistica. Giant ritiene che il consumatore finale debba informarsi direttamente dal suo Rivenditore Autorizzato di fiducia. Solo così saprà qual è il peso reale della sua bicicletta.
E+1 = 5499€
TaglieS, M, L, XL
ColorazioniElectric Red
ForcellaFox 36 Float Performance 27.5+, 170mm, 3-position Micro Adjust Grip Damper, Boost 110x15QR, e-Bike optimized
AmmortizzatoreFox Float X2 Performance, EVOL Large Volume sleeve, 2-position lever, 205x62.5mm Trunnion mount, custom tuned
ManubrioGiant Contact Trail, 35x800mm
TubosellaGiant Contact Switch, dropper, 30,9mm (S:100/M:125/L:150/XL:170)
SellaGiant Contact, Neutral
Pedali-
Leve del cambioShimano Deore XT, 12-speed
CambioShimano Deore XT, 12-Speed, Shadow+
FreniShimano Deore XT, BR-M8120, 4-piston, hydraulic disc, 203mm
Comandi frenoShimano Deore XT, BL-M8120
Pacco pignoniShimano HG-M7100, 11-51T, 12-Speed
CatenaKMC e.12 Turbo, EcoProteq, e-bike optimized
GuarnituraPraxis Wavetm 36T Cold Forged 4130 premium steel Praxis e-Cadet+ custom forged crankarm set (Q-factor=168, S/M:160, L/XL:165)
CerchiGiant e-TR1 27.5, Tubeless ready, 30mm inner width
MozziGiant e-TR1 [F] 110x15 [R] 148x12mm Thru-axle
RaggiGiant e-TR1
CopertureMaxxis Minion DHF 27.5x2.6" foldable, Tubeless, EXO+, 3c MaxxTerra[F] Maxxis High Roller II 27.5x2.6" foldable, Tubeless, DoubleDown, 2x120tpi, 3C MaxxTerra Compound [R]
E+2 = 4799
TaglieS, M, L, XL
ColorazioniTempus grey / Desert
ForcellaFox 36 Float Rhythm 27.5+, 170mm, Grip Damper, Sweep adjust, Boost 110x15QR, e-Bike optimized
AmmortizzatoreFox Float DPX2 Performance, EVOL Large Volume sleeve, 2-position lever, 205x62.5mm Trunnion mount, custom tuned
Pedali-
Leve del cambioSRAM GX Eagle 12-speed
CambioSRAM GX Eagle 12-speed
FreniSRAM Guide RE, 4-piston, hydraulic disc, 200mm
Comandi frenoSRAM Guide RE
Pacco pignoniSRAM Eagle PG-1230, 11-50T, 12-Speed
CatenaSRAM NX Eagle PowerLock, 12-speed
GuarnituraSRAM X-Sync Eagle 36T 104BCD chainringPraxis e-Cadet+ custom forged crankarm set (Q-factor=168, S/M:160, L/XL:165)
CerchiGiant AM 27.5+, Tubeless ready, 35mm inner width
MozziGiant eTracker Boost, Sealed cartridge bearing, 6-bolt, [F] 110x15 [R] 148x12mm Thru-axle
RaggiSapim E-Lite [r] Race [f]
Ovviamente la 0 è la più bella esteticamente, so che non è il forum giusto ma vi invito a vedere la versione muscolare della reign da 29, troppo bella
Andyz_it
4 Aprile 2018
1.582
610
Tortona
da questa foto sembra che anche quà il motore sia ruotato un pò verso il basso rispetto ai modelli 2019 (trance)
e comunque preferisco la linea piatta della cover batteria
